Rusted hood! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2006, 07:05 AM
kringold's Avatar
ATA Welding Technology
Last wiki edit: How to rebuild an engine Last photo:
Rusted hood!
I just got a 1979 GMC pickup this weekend and the hood has alot of rust. At this point it "appears" to be surface rust on just the top side. I'm going to strip the entire top side to bare metal. I've never done any body work or painting before, but I would like to get a good coat of primer on it afterwards, that will stand up to the elements. This is just going to be a beater truck, so it doesn't have to be fantastic.
What I have available to use is the Sears paint gun in the picture, that I bought for $8 at a thrift store, and a weak Coleman compressor. I have to wait on the compressor after about the second bolt, when I'm using my air ratchet. The only place to paint it in is my semi-enclosed attached carport, and I don't want to paint my house.
Now comes my questions. Will a weak compressor and a inexpensive gun spray primer? If so, what products should I look at? Or should I just use rattle can primer? Again, if so, what products should I look at? These are pretty much my only two options.
Old 08-20-2006, 07:21 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
My understanding is that most primers absorb moisture ,so that would not be good to protect it from the elements. Your best bet would be to prime and paint it.
Old 08-20-2006, 09:14 AM
Wow, you're up for a challenge with that much rust but it can be done. I'd look at the interior areas of that hood and if the front looks rusty inside I'd scrap it and find another. The gun will work for primer but it might be slow. A quality epoxy primer will protect the metal just fine but will chalk after some time in the sun. Sandable primer surfacers and acid etch primers break down much faster and absorb moisture.
Old 08-20-2006, 10:37 AM
kringold's Avatar
Deleted because it double posted.
Last edited by kringold; 08-20-2006 at 12:19 PM. Reason: On dial up and it double posted.
Old 08-20-2006, 10:43 AM
kringold's Avatar
The interior of the hood appears to be fine. The rest of the truck is blue, with the exception of the passenger side front quarter panel which came off a Blazer, and is brown. So this is a replacement hood.
That's what I was thinking. I'd have to shoot, wait, shoot, wait... and while I'm waiting what I shot will be dry before I shoot more. That's why I also asked about rattle can.
I eventually want to have a cheap (say $200) paint job put on it, but that may be a couple years down the road, and it sounds like that there isn't a primer that will wait that long.
So it looks like I will be rattle canning primer AND paint. Any recommendations on what to use? Again this will be a beater truck, maybe a work truck, so it doesn't have to be show quality.
Old 08-20-2006, 12:33 PM
kringold's Avatar
Also, I will be stripping this today, the hood is off and inside my shop. How long can I wait before I at least primer it? The wait is due to determining what product(s) or process to use.
Old 08-20-2006, 01:24 PM
ETriggs's Avatar
Self etching primer
For the primer, if you are going to leave it for a while in primer, I would suggest a self-etching and sealing primer. I used SEM Self-etching primer that is supposed to seal against rust. I left a part on my old truck in this primer for about 3 months before I painted it and it never rusted. This was during the nice humid, rainy summer in Alabama so it should work fine for you.
Eldon
PS: this was a rattle can and was ~$10/can
Old 08-20-2006, 01:58 PM
kringold's Avatar
Eldon
Great, that's what I'm looking for. I live in Western Washington and we don't tan but rust because of all the rain! However, I live in a town that doesn't always have what you need, so is there a second choice? Also, is there a rattle can paint that you could recommend?
Old 08-20-2006, 02:21 PM
ETriggs's Avatar
Self Etching primer
Any kind of primer that is an epoxy type that seals or a primer that is self-etching. If you have a DIY store nearby (Home Depot, etc) you can find this type of primer in the spray department. I think there is even a Rustoleum brand primer that is a sealing type. If not, look for a metal etch that will put a zinc layer on the metal. This will be a wash that you mix with water and wipe on the metal, leaving a yellowish tint to the steel. Then you can prime over the top and worry less about the rust.
I hope this helps!
Eldon
Old 08-20-2006, 04:21 PM
kringold's Avatar
I ended up buying Dupli-Color's T99 Primer Gey for "Truck, Van & SUV". Its the best Schuck's had. I'm assuming that this will work. I still have alot more stripping, plus welding to do before I spray. So I can get something else if I need too. How long can I let the bare metal sit before I need to get primer on it? With the work that I have left, it's looking like either tomorrow or the day after before I will be completely ready to spray primer over everything needed.
Old 08-20-2006, 04:34 PM
ETriggs's Avatar
Well, technically the metal could sit unpainted forever as long as you kept sanding off the surface rust. Most Rustoleum products do a great job of keeping the rust out for a rattle can. The standard primer will usually keep the rust off for about 1 month, depending on the thickness. Hopefully this helps.
Eldon
Edit: about the Duplicolor, it is a really good product. It was the base for a good chunk of the primer on my 1987 Toyota before I painted it.
Last edited by ETriggs; 08-20-2006 at 04:40 PM. Reason: Forgot to add something about Duplicolor
Old 08-20-2006, 04:59 PM
adtkart@aol.com
Any rattle can primer that you use will need to be removed before any repaint later. In reality, it probably won't be that difficult, as the stuff will not last that long anyway. I know of none that I would trust to not absorb moisture. As far as how long you can wait after stripping before priming, not long at all, specially if you are in a humid climate. As soon as you strip that metal, it will start to flash rust. If you are going to use a quality Epoxy Primer, you have a little more time, because of the sealing characteristics. Anything less than epoxy, and I would prime it that day.
As an added note... There are no "Front Quarter Panels" on that vehicle. They are "Fenders".
Aaron
Old 08-20-2006, 07:05 PM
kringold's Avatar
Originally Posted by adtkart
Any rattle can primer that you use will need to be removed before any repaint later. In reality, it probably won't be that difficult, as the stuff will not last that long anyway. I know of none that I would trust to not absorb moisture. Aaron
That's why I kinda intend on hitting it with a coat of color also. Then hopefully nothing will have to be stripped when I have the whole truck ready for paint, which will be awhile. Your thoughts?
As an added note... There are no "Front Quarter Panels" on that vehicle. They are "Fenders". Aaron
I know gimme a break... I was still on my first cup of coffee and it was reheat from yesterday!
Old 08-20-2006, 09:24 PM
kringold's Avatar
Rustoleum
I think there is even a Rustoleum brand primer that is a sealing type. Eldon
I didn't mean to ignore your suggestion of Rustoleum, however I did a search on rattle can primers before posting here and after reading the first two results, I have decided to stay away from it.
http://www.hotrodders.com/forum/sear...earchid=599876
Old 08-20-2006, 10:20 PM
Buy yourself some good quality epoxy primer, Southern Polyurethanes is top notch and very economical when compared to even spray cans of junk 1K products. You can epoxy that panel and rest assured it will last for years and years without paint-I've got a truck and some parts here that confirm this. Although epoxy chalks when exposed to sun it takes a very very long time to degrade to the point that protection is compromised. Once you're ready for paint simply sand the surface of the primer and shoot on one fresh coat then paint that puppy.
SPI epoxy Southern Polyurethanes
Primer economics: SPI epoxy is 51cents per sprayable ounce
Rattle can self etching primer at $10 per 12ounce can = 83cents per sprayable ounce, add in the fact that 50% is solvent and the cost doubles.
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 09:14 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 08:10 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 08:29 AM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 10:24 PM
Door Alignment Ron M Body - Exterior 2 08-21-2004 02:43 AM
