Rustoleum Oil vs Duplicolor Lacquer - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 06-19-2010, 08:53 AM
Yeah...I guess I didn't see the highly polished "NO RAT RODS"
sign.
  #32 (permalink)
Old 06-19-2010, 09:43 AM
roger1's Avatar
Deleted duplicate post
  #33 (permalink)
Old 06-20-2010, 01:46 PM
Last wiki edit: Window removal and installation Last photo:
Wiki Edits: 11
I have messed around with both paints, basically just for experimentation. The Duplicolor sucks. It's just their spray can lacquer in a different can. I think the clear is terrible but I may just be ruined from using conventional 2K urethane clear coats.
Rustoleum has some potential. First don't use anything but the "professional" version. Second, always use an enamel hardener additive, especially if you are going to spray. Consider Rustoleum old school enamel and use accordingly. The recommendation on the cans says to use acetone as a reducer when spraying. I've tried it and enamel reducer both and can't tell any difference in spraying or end result. Rustoleum seems to be good value for the money. I never have high expectations for anything that is cheap. Show car finish it ain't. But it's pretty cheap and does what it's supposed to do. Keep in mind that the Rustoleum people never intended it to be used as automotive paint.
  #34 (permalink)
Old 06-20-2010, 05:55 PM
I agree with your observations 100%, do you have any pics of your Rustoleum experiment, that others can see..............MC
  #35 (permalink)
Old 07-06-2010, 12:21 PM
Wiki Edits: 11
No, sorry. What I did was paint some on a leftover bent hood. Some "silver" which is more like aluminum and worthless. Next a square foot of yellow which I left alone. Then a square foot of glass black which I color sanded and buffed a bit. Then I laid the hood against the wall on the sunny side of the garage and left it for a year and a half. When I got sick of looking at it I tossed it. Before I did, I checked out the paint. The yellow had a slight haze like it was starting to "chalk" a little. Polished right up though. The gloss black merely needed some dirt washed off and it looked as good as when I set the hood out.
Frantz filter system, buy or not to buy? zipfactor Engine 59 Yesterday 10:58 PM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
oil suggestions and preferences timemachine Engine 2 05-07-2008 02:07 PM
Is it no good to have a High volume oil pump? Calderone Engine 17 01-31-2008 05:26 PM
Oil Change THX_138 Hotrodders' Lounge 25 12-20-2006 03:01 PM
