rustoleum paint or summit ss acrylic urethane - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: rustoleum or ss summit racing au
spray rustoleum profesional series paint on truck 1 25.00%
scuff old paint and spray ss summit acryilic urethane 3 75.00%
Voters: 4. You may not vote on this poll
Old 12-01-2011, 08:55 PM
rlb3's Avatar
My 91 chevy stepside is in need of some sort of paint job I want it to be black.
Should I just spray some rustoleum proffesional paint on it or
Should I just sand all the clear off and scuff the paint then spray some single stage summit racing acrylic urethane on it?
Old 12-01-2011, 09:06 PM
Wiki Edits: 31
I would reccomend against Rustoleum. There basic 'protective coating' has no UV inhibitors, is Alky'd enamel and is not really meant for this use. If you step up to there professional line, it is basically the same. If yo step up to there urethane product, it is nearly the same cost as the Summit paint.. FWIW, Summit pain is Kirker, and decent paint, but also www.tcpglobal.com has there 144 kits, which is 144 colors to choose from for $144 for the kit ( material to paint A vehicle ). the price may be diffrent now, but they have decent cheap paint.
Old 12-01-2011, 09:07 PM
Project89's Avatar
work or yard truck, or something u drive every day?
if its somethign u wanna just throw paint on id do the rustoleum, if ur going to keep it a while etc use the summit paint
edit
the black camaro nexto my name that says last picture is a camarop that was painted with black rustoleum. no prep work at all they just slapped it on there with no wetsanding or polishing and it came out pretty good.
they didnt bother with the extra work to make it look real good cause the car is being built for the 24 hours of lemons races
Old 12-01-2011, 09:14 PM
dinger's Avatar
This one has raised a lot of conflict. Here is a post to read: The ultimate budget paint job thread /w pics (rustoleum paint)
Sending this to the lounge, it really has no technical merit, just opinion based.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 12-01-2011, 09:17 PM
rlb3's Avatar
edit
I purchased the truck for $500. And right now I'm redoin the front suspension and geting it running right I plan to keep it for a while its about to be my daily driver I just don't like the peeling clear coat look
Old 12-01-2011, 09:31 PM
Project89's Avatar
the rustoleum take some work to get it to look good, id take a look at some os the rusto threads and then make ur decision.even though im doing the rusto paint now, im striping mine off in the spring to have the car sprayed metalic blue and silver, both of which are summit single stage paints
Old 12-01-2011, 09:59 PM
life is a temporary assignment
I wouldn't waste my time doing it with rustoleum ..
Mixing Acrylic Lacquer with Acrylic Urethane waterdude Body - Exterior 23 02-16-2011 08:00 PM
Summit epoxy w/ Rustoleum reducer greenmoonshine Body - Exterior 21 09-21-2010 07:50 AM
Acrylic Lacquer over Urethane paint. northiam Body - Exterior 10 03-17-2008 08:21 AM
Urethane clear over acrylic? bug67 Body - Exterior 5 08-14-2007 03:21 PM
acrylic enamel vrs urethane americanLT1 Body - Exterior 4 09-15-2005 10:23 AM
