Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rustoleum vinyl paint
Old 01-18-2012, 08:15 AM
47 ford coupe 47 ford coupe is offline
JERRY 47 FORD COUPE
Originally Posted by HelmetTester
has anyone used this? its new and i am lookin for something to change the color of a vinyl door panel. they say it actually contains vinyl and i would think it would be pretty durable. its not just a dye like the others where you can only clean up the appearance of what you already have. any info appreciated.
dennis
when it comes to dying vinyl, there is a lot of simple things you can do. are you trying to change the color? some of the dye colors are transparent. what it means is you may have change the color to a solid color first and then go to a color that will cover it. example spray red on a white door and you will have pink. change to tan and you will get red. vinyl needs to be washed real good for 1 prep, then wipe it with acetone. spray a very light coat on the vinyl first (about a foot away) you will probably use 5 to 7 coats very light. i have been doing this since 1982. 47 ford
