Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rusty chain
Thread: Rusty chain
Old 03-04-2005, 10:21 AM
beyondhelp's Avatar
beyondhelp beyondhelp is offline
Cad Power rules!
You could also try electrolysis.. http://antique-engines.com/electrol.asp
http://www.rowand.net/Shop/Tools/Electrolysis.htm
What you need:
* A non-conducting container - a large plastic bucket works really well.
* Battery charger - big is better, however even one able to produce 6 to 10 amps should do. A student recently used my site as the basis for a school project and used a computer power supply in place of battery charger.
* Sacrificial electrodes. Concrete reinforcing rod works well (rebar) cut into lengths about 4" taller than your bucket or container. Do not use stainless steel! The results are a health hazard and illegal (more on that later)
* Arm and Hammer LAUNDRY soda, also called washing soda.
* Wire and/or cables for connecting electrodes together.
* Water.
* Small lengths of small chain (used to suspend the rusty parts in solution) or some other means to suspend the part to clean into the solution.
....................... too much detail to paste the whole page.
