Rusty chain
I found a rusty chain suitable for towing. I want to clean it up. Since I do not have access to sand blast or glass bead. Anyone got any suggestions on how to get the rust off, without getting myself filthy?
Great idea
But since it is winter. Dragging it through the snow prob won't do the trick.
Update
I took a cpl gallons of water and mixed in an alkali and a chemical oxygen scavanger. The heavy rust came off immediately and after 4 hours of soaking, half of the chain is silver already.
ingredients
I used appx a 1/4 cup of each to 2 gallons of water. I used Caustic Soda and Sodium Sulphite. Its gonna take about 8 hrs by the way its going. I didn't want to make it too strong. I didn't know how long it would take to react.
You could also try electrolysis.. http://antique-engines.com/electrol.asp
http://www.rowand.net/Shop/Tools/Electrolysis.htm What you need: * A non-conducting container - a large plastic bucket works really well. * Battery charger - big is better, however even one able to produce 6 to 10 amps should do. A student recently used my site as the basis for a school project and used a computer power supply in place of battery charger. * Sacrificial electrodes. Concrete reinforcing rod works well (rebar) cut into lengths about 4" taller than your bucket or container. Do not use stainless steel! The results are a health hazard and illegal (more on that later) * Arm and Hammer LAUNDRY soda, also called washing soda. * Wire and/or cables for connecting electrodes together. * Water. * Small lengths of small chain (used to suspend the rusty parts in solution) or some other means to suspend the part to clean into the solution. ....................... too much detail to paste the whole page. |
I didn't know muriatic acid eats away at rust. How well does it work?
I have alot of that stuff. My stepdad uses it for sometimes when he's redoing old brickwork. He uses it to clean up the facing of the bricks. |
There are a lot of great ideas here. I thought of some ideas that were exactly the same here! Good luck.
I like the electrolysis method. I bought a plastic storage tub at Walmart for a couple of bucks. I've been using lye which I found at the grocery store in the drain cleaner area. Look up the exact procedure and make sure you get the polarity right on your charger. One of the nice things is it essentially quits when the rust is gone. You don't have to worry about overdoing it. I salvaged a number of internal transmission parts in my tub as well as some nasty old brake drums.
DIY electrolysis
Get a plastic bucket large enough to fit the rusty item into and cover it with water. Mix in one tablespoon of laundry soda per gallon of water (adding more wont speed up the process) Attach a piece of wire to the item so that it sticks up out of the water a few inches. Get another piece of metal like a length of pipe or angle iron (no stainless) which will act as your anode. Place the anode into the bucket but not touching the rusty part and connect the positive(+) lead of the battery charger to it and the negative(-) lead to the wire attatched to the rusty part. turn on the charger and let 'er rip, Also dont let the battery clips set in the solution as they will disolve
Every few hours or so turn off the charger, remove your anode, and wipe off the crud that will stick to it. Also make sure you do this in a well ventilated area as the process releases hydrogen gas which is explosive (explosions = fun, blowing up your garage and scaring your neighbours = well could be fun but probabally not the best idea) |
We used to use Zud to clean rust rings (from tin cans) in porcelain apartment sinks. It contains oxalic acid, which dissolves rust. Bartender's Friend is a similar product. They're usually found near the other powdered cleansers (Comet, etc.) at the grocery store. I don't know how much you'd need, but a whole can in a bucket of water deep enough to submerge the chain for a couple of days might work.
| Recent Garage - Tools posts with photos |
| SBC, Holley floods, fixed, seems timing chain wrong | 360Camaro | Engine | 2 | 09-01-2004 10:16 AM |
| Timing Chain | jrm123180 | Engine | 2 | 08-13-2004 09:15 PM |
| 454 new timing chain and gear, will not start | Old and worn out | Engine | 6 | 12-04-2003 09:15 AM |
| timing chain tension | VETTE GUY | Engine | 3 | 06-27-2003 02:15 AM |
| Timing gears vs double roller chain timing chain | Jag Daddy | Engine | 12 | 05-24-2003 10:22 PM |
