I am lost I think, is this a car/tow dolly frame that we are talking about? Rust-O-Leum makes a Rusty Metal Primer that is the red oxide color, Red Oxide is the best primer you can get for metal applications for preventing rust, it is the purest primer than any other color. I have used the rustoleum rusty metal primer many times, I primed my truck frame with it and never painted over top of it and I can't see anywhere that it has flaked off in the past year.
I wouldn't waste time brush painting it. I used an airless sprayer with this with good results. I think I pulled the pick up screen because the viscosity was pretty thick. Pressure wash it a couple of times and let dry, once again let dry.
I primed and painted a trailer and very rusty water tank for a fire fighting trailer at my ranch (very remote) about 4 or 5 years ago and its held up great. I used the Rustoleum Rusty metal primer not POR 15 |
Primer is made to bond to bare metal. I wouldn't prime over rusty/flaky paint. I would sandblast the frame the best you can or at least wire wheel as much as possible before priming. And before finish painting use a palm sander with like 80 grit paper and lightly sand the primer just to rough it up before finish painting other wise the paint will not hold as good. Just stick with the rust oleum don't cheap out to same a few bucks and buy a "universal primer" the only thing universal about universal primer is they go well in any trash can. I believe rust o leum is a universal primer but it is focused on metal rather than plastic or wood.
skip the por 15 unless you are going to put a topcoat on. it does not hold up to uv rays. tractor supply sells a primer and implement paint. used the red oxide primer and painted it black but they have the paint in many colors. almost 3 yrs now in the fla sun and it still looks good and touches up easy
it works great for trailres and stuff ...not for trailer queens,LOL...
Dozers backhoes generators.That kind of stuff you just want all one color and have it last a couple years....you dont sand this, you wire brush(by hand)to get the loose rust off...but if you want to show it it off or spend your time shining turds then theres always 8oo.oo a gal paint that looks great and 500.oo primers you can use..I'd rather spend my time working on the cars at my shop than the trailers that get them there.rustolium fits the bill perfectly.. |
IF you have an air compressor you could go to Wal-Mart or TSC and buy a cheap spray gun for like 20 bucks. That way you can just paint the trailer and just throw the gun away if you don't want to clean it. This is what I did for my spray in bed liner, Just bought a cheap spray gun from TSC for like 23 bucks and threw it away when I was done. You will probably have 10 bucks or so in brushes and rollers and trays and all that garbage and not have near as good results, all paint applies and sticks better when sprayed on.
yeah, a gun is a lot easier and faster..
| frame pics | willowbilly3 | Hotrodding Basics | 6 | 12-08-2006 10:25 AM |
| Help with the PREP of my frame?? | Bud's 27 T Touring | Body - Exterior | 3 | 05-02-2006 08:43 PM |
| Frame mods | dusterbd | Suspension - Brakes - Steering | 5 | 11-05-2004 01:00 PM |
| Review of FatMan IFS Airbag install 1938 Chevy PU | Grashopr | Suspension - Brakes - Steering | 3 | 08-25-2003 11:16 PM |
| repairing a cut up frame | jniolon | Suspension - Brakes - Steering | 3 | 04-12-2002 06:42 AM |
