rusty frame? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 08-29-2005, 07:26 PM
rusty frame?
hi there---great site, i wonder if anyone could give me some advise on repairing a frame on my 88 nissan 4x4,the inside part of the box frame is cracked and badly rusted for about a foot around the shock support and leaf brackets. the outside and the rest of the frame is pretty good. the truck itself is a great runner but i don't know if i can repair it myself, i do have some welding experience,any pro advice would be great. thanx rupert p.s. i have to drive 30 miles on rough dirt roads to go to town and back hence the 4x4 is pretty handy//
Old 08-29-2005, 10:58 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Hmm . . . If you were doing a major restoration I would suggest buying a solid used frame. Those trucks are plentiful @ the junk yards. However it sounds like you want to patch and repair and just keep it on the road. In the latter case, you are pretty much restricted to just what you described in your post - search for, cut out and replace the rotten plates. "Some" welding experience is relative - can mean you can strike an arc 3 out of 4 times w/o killing yourself all the way up to being able to run a bead that would pass a certification test. If you are not pretty far up the scale to the certified weld, I would recommend you take the truck to a good welder and ask him to do the minimum ($$$) to get the truck safe again. If you want a show stopper, go for the replacement frame.
Old 08-30-2005, 01:27 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Glad to have you here at Hotrodders.
59 Chevy pickup frame woes! Li'l Pine Suspension - Brakes - Steering 33 07-08-2009 08:24 PM
86 s-10 frame bent catscan4free Suspension - Brakes - Steering 3 03-27-2007 09:46 PM
rusty floors, and frame rails mercury88 Body - Exterior 2 08-05-2005 11:51 AM
Cantilever system for air bags 53LEDSLED Suspension - Brakes - Steering 17 12-05-2004 03:26 PM
Body & Frame question ruiner808 General Rodding Tech 7 09-14-2003 05:54 AM
