-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   rusty water - when i drain compressor (http://www.hotrodders.com/forum/rusty-water-when-i-drain-compressor-206542.html)
geeky2 10-03-2011 02:24 PM
hello all,
i purchased my compressor used.
is it a serious issue if i see a small pool of rusty water coming out of the drain (at the bottom of tank) - when i drain it?
i drain the tank after EVERY use - but i suspect that the person who owned the tank before me - did not do the same.
thank you,
mark
Irelands child 10-03-2011 02:50 PM
It will eventually open up a pinhole somewhere on the bottom - but who knows when. My little 2Hp Craftsman 12 gallon 120V went to compressor heaven a couple months ago - it had been spitting rusty water for 20 years. I bought it in 1971.
35terraplane 10-03-2011 03:09 PM
Rusty water
Originally Posted by geeky2
hello all,
thank you,
mark
You are right, it just wasn't drained enough. Mine is a very big one, I don't even know the size, or age, but I get very little rusty water, But it was used in a body shop for years, and I'm sure they took good care of it.
Bob
geeky2 10-03-2011 03:55 PM
hello,
thank you for the reply.
my primary reason for the concern is - i am setting up a paint booth in my garage and i want to make sure that my filtration system is adequate (within reason ;)
i am still learning what i need for air filtration.
i installed a desiccant system (see embedded image)
while re-doing the plumbing (1" galvanized pipe) for the new desiccant system, i noticed small / faint traces of rusty power / dust in the pipe. i am not sure where this residue came from. my assumption is that it originated from the compressor tank.
https://picasaweb.google.com/1135253...55534946529746
geeky2 10-03-2011 03:58 PM
sorry - here is a link to the pictures i have for the filtration / desiccant system.
paint booth pictures
thank you mark
SkullyRods 10-03-2011 04:25 PM
some info
I have just finished installing a compressor and air line in my garage. Used ½ “ copper pipe allows enough volume through to do most everything including sand blasting with a pressure pot blaster.
I incorporated one water trap a desiccant dryer and add a line drop with valve on it. One of the recommendations to take in to consideration is to slope your air line away from your compressor so as to not get any condensation flow back to the holding tank.
geeky2 10-04-2011 02:31 PM
thank you for the reply,
excellent point !
thank you,
mark
mitmaks 10-05-2011 10:44 PM
Maybe coat inside of air compressor with POR15
Mach1460 10-10-2011 07:17 AM
I bought a brand new sanborn 80 gallon about 6 months ago. After the first couple weeks of using it the water came out a little murky/rusty and has ever since. Im in south dakota where we definately have a wild climate and weather from -40 to 105 with 100% humidity. Im not worried about it. You would think they would coat the inside of the tanks from the factory but then I guess we wouldnt have to buy a new one ever :) I drain mine every day ( id forget once in a while and go 2-3 days with out draining) Ive been told there is an "automatic" drain system that you can install and it will let out a spurt of air every so often, might be somehting to look into....
