rusty water - when i drain compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2011, 03:24 PM
geeky2's Avatar
1968 Ford Mustang - beginner
Last journal entry: garage work
hello all,
i purchased my compressor used.
is it a serious issue if i see a small pool of rusty water coming out of the drain (at the bottom of tank) - when i drain it?
i drain the tank after EVERY use - but i suspect that the person who owned the tank before me - did not do the same.
thank you,
mark
Old 10-03-2011, 03:50 PM
Irelands child's Avatar
It will eventually open up a pinhole somewhere on the bottom - but who knows when. My little 2Hp Craftsman 12 gallon 120V went to compressor heaven a couple months ago - it had been spitting rusty water for 20 years. I bought it in 1971.
Irelands child
Old 10-03-2011, 04:09 PM
35terraplane's Avatar
Rusty water
Originally Posted by geeky2
hello all,
thank you,
mark
You are right, it just wasn't drained enough. Mine is a very big one, I don't even know the size, or age, but I get very little rusty water, But it was used in a body shop for years, and I'm sure they took good care of it.
Bob
Old 10-03-2011, 04:55 PM
geeky2's Avatar
hello,
thank you for the reply.
my primary reason for the concern is - i am setting up a paint booth in my garage and i want to make sure that my filtration system is adequate (within reason
i am still learning what i need for air filtration.
i installed a desiccant system (see embedded image)
while re-doing the plumbing (1" galvanized pipe) for the new desiccant system, i noticed small / faint traces of rusty power / dust in the pipe. i am not sure where this residue came from. my assumption is that it originated from the compressor tank.
Old 10-03-2011, 04:58 PM
geeky2's Avatar
sorry - here is a link to the pictures i have for the filtration / desiccant system.
paint booth pictures
thank you mark
Old 10-03-2011, 05:25 PM
some info
I have just finished installing a compressor and air line in my garage. Used copper pipe allows enough volume through to do most everything including sand blasting with a pressure pot blaster.
I incorporated one water trap a desiccant dryer and add a line drop with valve on it. One of the recommendations to take in to consideration is to slope your air line away from your compressor so as to not get any condensation flow back to the holding tank.
Old 10-04-2011, 03:31 PM
geeky2's Avatar
thank you for the reply,
excellent point !
thank you,
mark
Old 10-05-2011, 11:44 PM
mitmaks's Avatar
Last journal entry: Grille
Maybe coat inside of air compressor with POR15
Old 10-10-2011, 08:17 AM
Mach1460's Avatar
Last journal entry: Project 92' Eddie
I bought a brand new sanborn 80 gallon about 6 months ago. After the first couple weeks of using it the water came out a little murky/rusty and has ever since. Im in south dakota where we definately have a wild climate and weather from -40 to 105 with 100% humidity. Im not worried about it. You would think they would coat the inside of the tanks from the factory but then I guess we wouldnt have to buy a new one ever I drain mine every day ( id forget once in a while and go 2-3 days with out draining) Ive been told there is an "automatic" drain system that you can install and it will let out a spurt of air every so often, might be somehting to look into....
Used compressor - rusty tank? Slipangle Garage - Tools 15 03-16-2012 09:51 AM
Water In Compressor Pump 69lm69gp Garage - Tools 30 12-22-2010 09:37 AM
air compressor drain plug tcoop Garage - Tools 20 12-04-2009 08:42 PM
Best water trap for a compressor Jcfoote60 Garage - Tools 20 07-26-2006 06:05 PM
Compressor Water Problem MI2600 Garage - Tools 8 12-26-2004 07:54 PM
