Ok, I once had a 1972 Ventura that I wrecked. My dad and I have been in the process of putting another one together and it is in the shop now getting the new motor installed. I would like it if you could give me an idea of what it will put down at the wheels and what it may run in the 1/4. I will be dynoing it and taking it to the track when it gets done, so it will be fun to compare that to the guesses.
496
9.5:1 compression
fully ported 2.19 1.88 valve 049 heads
248 254 @.050 .600 lift solid flat tappet cam
port matched Victor Jr intake
Pro Systems 1000cfm carb
2 & 1/8th inch primary hooker super comps with cutouts
pro magnum roller rockers...
turbo 400
3200 stall
3.55 gear
slicks and cal tracks
Assume the car weighs ~3500 with me in it.
Also, you can take a look at the old ventura before and after being built and after the wreck; along with the new ventura on its way to the shop for the motor in my gallery if you want to see them.
Thanks a lot
Adam
496
9.5:1 compression
turbo 400
3200 stall
3.55 gear
Thanks a lot
Adam
