s-10 4 x 4, how to eliminate it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2010, 05:38 PM
I have a 4x4 s-10 and my 4 wheel doesn't work which is o.k. is there a guide sheet for me to unhook all the items I don't need? Never done this before, thanks, Dana
Old 02-13-2010, 07:06 AM
ericnova72's Avatar
More for Less Racer
If it doesn't work and you are not going to repair it to working condition, why mess with it at all??, just leave it alone. It's just a question, before you open a can of worms.
Old 02-13-2010, 09:00 AM
If it has locking hubs then just be sure they are un-locked, thats all you can do really. If it's the later full time or semi auto type then you dont need to do anything.
Old 02-13-2010, 03:19 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You sure you don't care about 4wd working? I would think it would be good to have living in Michigan, especially during the winter months.
Old 02-13-2010, 03:32 PM
poncho62's Avatar
Wiki Edits: 5
Trade it for a 2 wheel drive one..........If you think you can just take a few parts off and it will be the same as a 2 wheeler, you are mistaken.........They are completely different.
BTW.......there are really just 2 things likely wrong with the 4 wheel drive........a vacuum leak or a bad actuator.
Old 02-14-2010, 07:16 AM
I am using this as a frame swap, and I'm thinking why drive around w/extra luggage? (Bldg a panel van and rodding it)
Old 02-14-2010, 07:24 AM
poncho62's Avatar
Wiki Edits: 5
Not to sound critical, but since you are going through all that trouble, might be better to start with a frame that is set up for what you want.....like a 2 wheel drive s10 frame...........will save money and effort in the long run.....
Just because you have something on hand, doesn't mean its the right thing to use.....just my opinion.
Old 02-14-2010, 08:08 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
If you decide to use the 4x frame and scrap the front parts, you will have to leave the outer axle stubs in place. They are needed to set the pre-load on the front wheel bearings.
Old 02-14-2010, 10:07 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
That is correct, and doable, but I'd still recommend finding a 2wd frame to begin with, especially if you plan on V8ing it, 2wds have a much wider selection of quality headers available, not to mention being able to do drop spindles and/or brake upgrades that would/will be difficult at best with a 4x4 chassis and running gear, along with the odd wheel offsets that a 4x4 chassis requires.
Old 02-20-2010, 05:35 PM
Thanks for all the input and suggestions, Dana
7 deg versus 10 degree ? Guy Hiltz Engine 3 10-29-2006 01:05 AM
Brake lights switch oldsmo Electrical 4 10-19-2006 11:23 AM
unusual 10 bolt GM diffy off '75 SW... paulo 1 Transmission - Rearend 2 08-16-2006 08:10 PM
Engine Vacuum is showing 10 and no higher? ataririder Engine 42 02-18-2003 07:12 PM
10 0/0 theory dinger Hotrodders' Lounge 3 09-12-2002 08:14 AM
