S-10 4x4 rear end swap into 57 chevy wagon - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2012, 01:10 PM
I'm wanting to change the rear end in my 57 chevy wagon to an s10 4x4 rear. All help in doing is appreciated. I bought 2w/d s10 rear end to find that it would to narrower. So I need info on the 4x4 rear.
Old 11-30-2012, 02:12 PM
big gear head's Avatar
High Performance Rear Ends
4X4 rear end is 4 inches wider. The first gen Camaro rear end is 60 inches, and the FOX body Mustang 8.8 is 59 1/2 inches. Most of the S10 rear ends are the weak 7.5 10 bolt. A '72 or later Nova or other X body 8.5 is also 60 inches and would be a much better choice.
The Following User Says Thank You to big gear head For This Useful Post:
kwilliams89 (11-30-2012)
Old 12-12-2012, 02:16 PM
jayseasBlue56's Avatar
the 4x4 r/e will work great, if your not racing it hard.It's a good unit disc brakes different gear selections.it's been used plenty of times, manny at the wrecd for cheap.
Old 12-12-2012, 03:03 PM
RWENUTS's Avatar
If you're gonna use a S10 4x4 be aware that a S10 ZR2 rear is even wider at 62 inches.
Easiest 57 Chevy wagon RR end swap. eyesore 1 Transmission - Rearend 4 07-11-2008 05:18 AM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
Chevy rear end swap Truplayainfla Introduce Yourself 1 10-23-2004 11:07 PM
rear end swap into 61 chevy 61wagonair Transmission - Rearend 1 07-07-2003 08:35 PM
