s-10 5 speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2007, 10:14 AM
runn141's Avatar
s-10 5 speed
is a 5 speed from a 90 model s10 with a 4.3 the same as a 5 speed from a 90 model full size chevy with a 350? if so are they the same strength?
Old 01-06-2007, 10:41 AM
BigMike
your tranny will hold up as long as you dont put the pedal to the floor and try to shift. it wont last to long like that. you should be alright to use the s10 tranny with out any problems
Old 01-06-2007, 12:37 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
They do not show the same tag numbers in my book..would require some more investigation to determine if they are the same..should both bolt up tho..
The truck one is a Getrag unit/ not sure on the 4.3 tranny..either one would be a better choice for an S-10 swap than the one that comes with the four cyl version..
Sam
Old 01-06-2007, 01:19 PM
Hippie's Avatar
Last journal entry: HEI comparison.
The 4.3 and 5.7 use the same flywheel and bellhousing bolt pattern and the '89 V-6 and V-8 C1500's both use the Getrag. The Getrag in my 4.3 '89 C1500 is the same as the 5 speed in a '96 4.3 S-10 although they changed the designation slightly and call it something else, IIRC it is now referred to as a New Process but it's still the Getrag. My friend owns a transmission shop and verified it for me becuse I was looking at a wrecked '96 S-10 for parts for the 4.3 and 5 speed for my '89 but the '96 is a "true" Vortec and my TBI wouldn't work on it without way more work than the truck is worth. I should have bought it just for the trans but didn't.............. oh well. Now a 3/4 ton fullsize may be a different story. I didn't check that.
unusual 10 bolt GM diffy off '75 SW... paulo 1 Transmission - Rearend 2 08-16-2006 08:10 PM
s 10 willys bob cutler General Rodding Tech 6 07-29-2005 08:34 PM
Engine Vacuum is showing 10 and no higher? ataririder Engine 42 02-18-2003 07:12 PM
10 0/0 theory dinger Hotrodders' Lounge 3 09-12-2002 08:14 AM
40 ply/s 10 clip gcorbit Suspension - Brakes - Steering 0 01-28-2002 03:53 PM
