s-10 axel width - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2009, 09:17 PM
s-10 axel width
might have posted this in the wrong place before.
what is the width of an s-10 rear axel, 2wd. and what will interchange.
Old 11-09-2009, 11:23 AM
scapegoat's Avatar
I put a ford 8.8" in my 2wd s10. It was a direct bolt-in. They are wider but I just used different offset wheels and different lug pattern. It came out of an explorer and it is 31 spline,posi,373 gear and disc brake. Gotta picture around here somewhere...
ID:	41854   Click image for larger version
Old 11-09-2009, 12:59 PM
fast68's Avatar
likes chevy trucks & boobies
s10 and explorer are the only interchangeable directly due to spring pack distance.
but shocks mount differently
also you would need the explorer driveshaft yoke and a special u joint from napa
we just replaced the 8.8 under a 94 explorer the other day
and i have a 91 s-10 2wd pickup right now
so if you want pics measurements etc lemme know
but the explorer axle is wider i know that yeah
Old 11-09-2009, 02:09 PM
XNTRCI-T's Avatar
AKA Lee in KC
There are two S-10 axle widths... 54.5" and 58.5". I don't remember which is 2WD and which is 4WD.
Old 11-09-2009, 04:57 PM
scapegoat's Avatar
I used the s10 shock mount that is part of the plate that the u-bolts go through. The explorer is about the best swap there is for an s10. I spent $300 on mine. You can't beat the value. A 31 spline axle with a posi and disc brake for $300. You could find it even cheaper depending on where you're located.
Old 11-09-2009, 05:43 PM
Thanks for the response. this question is for my latest project. A 49 international going on an s-10 chassis. I have a 355 sbc to go in it. I don't think the stock rear end would handle the abuse. not sure what transmission I am going to use at this point, t350, t400, 4 speed or 5 speed. time will tell. this truck will be a 4 link rear with air bags front and rear.
Also thinking about a 3" chop. that one is undecided also.
Has any body have any picts of one done like this. or any suggestions on the subject.
any way thanks again for the feedback.
10 bolt spacing and gear backlash question ChevyThunder Transmission - Rearend 3 12-16-2005 09:05 PM
s10 rear width 85 regal Transmission - Rearend 3 11-14-2005 01:24 AM
Engine Vacuum is showing 10 and no higher? ataririder Engine 42 02-18-2003 07:12 PM
10 0/0 theory dinger Hotrodders' Lounge 3 09-12-2002 08:14 AM
40 ply/s 10 clip gcorbit Suspension - Brakes - Steering 0 01-28-2002 03:53 PM
