S-10 Axle play Problem? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-03-2005, 03:11 PM
AMDAP's Avatar
CEO of The AMDAP Mulisha
Anybody got any input from the pics? I know that something is wrong with that axle, but I can't see why it ended up like that. ANY help is SO appreciated...Thanks!
  #17 (permalink)
Old 12-03-2005, 03:25 PM
The axle shafts look fine, looks like you might need a new spider gear!
Hard to really tell in that pic though......I could be seeing things.
Let's see what someone else thinks.
  #18 (permalink)
Old 12-03-2005, 05:24 PM
1931 Ford 5 window
Last journal entry: Door Panels
S10 rear
OK, I just got a 95 S10 rear for my rod and would like to replace the bearings how difficult is it to do and do I need any special tools? Also how much oil do you add back once I'm done with the bearing replacement job? and anything else I should replace while I'm at it?
  #19 (permalink)
Old 12-04-2005, 08:06 AM
The wheel bearings are very easy to replace. Just rent a slide hammer puller at autozone etc. then use it to snatch the old bearings out. Use a socket or tool to tap in the new bearing evenly then put in new wheel seal (put a bit of grease on it so it won't rub too much when you slide in the axle) over that and you are finished. Sounds harder than it is. It take about 2 and 1/2 of those quart size 80-90 gear oil bottles at wally world to fill the rear end. I put it in until it starts to run back out and then it is full.
  #20 (permalink)
Old 12-04-2005, 10:22 AM
Bumpstick's Avatar
Hammer and a torch
My thoughts are that is a gov-lock and either the C clip is worn or possibly the shim that is under the passenger side spider gear is gone or possibly the gear is chewing into the carrier housing...? This would account for the end play... The bevel you mentioned on the passenger side shaft is nothing out of the ordinary from what I have seen...? (axles look good on that end...)
Main reason for the "clunking" sound is the clutch on the left side is binding or does not have the correct lube...? Gov-locks are good for nothing but pulling boats out at the ramp... Any kind of real power or uneven traction and they tend to explode... Go with an Eaton or other good rebuildable aftermarket posi unit even to just replace that junk...
  #21 (permalink)
Old 12-04-2005, 02:22 PM
AMDAP's Avatar
I don't think anything is binding. It is just the axle hitting the pinion shaft and then the c clip hitting the spider gear. The reason I am worried about the bevel, is because it isn't uniform. It is worn more on one side than the other. Also it just looks like an open carrier to me. How do I tell if it has a gov-loc? Also is it hard to change spider gears? Hard like setting a ring and pinion?
  #22 (permalink)
Old 12-04-2005, 04:25 PM
Bumpstick's Avatar
Hammer and a torch
The pic you supplied of the carrier has that block inbetween the 2 smaller spider gears which remindes me of a gov-lock setup...? Possibly those small 10 bolt rears had this even with open carriers...? Put up a pic of the other side of the carrier to be sure...
Also the play on the passenger side might be linked to the shims (or lack of...?) on the passenger side spider drive gear and carrier housing... If the play of the gear is considerable then the spiders gears may be making the popping effect because of the clearance becoming to much at times and the gears tend to bind from the distorted angles...
  #23 (permalink)
Old 12-06-2005, 11:43 PM
s10 axle play
I do not believe it is the axle end play you should be concerned with. Does it only clunk when you turn? If so, the stock GM Gov-lok like you have is prone to have problems. If this is grandmas car I would take the Gov-lok out before it grenades and destroys the whole differential. You can replace it with an open differential. If you wanted to replace axle bearings all you need is a slide hammer, if you do not have one you can rent it from Napa.
  #24 (permalink)
Old 12-07-2005, 01:37 AM
AMDAP's Avatar
Thanks for the input jawsgear! I was just talking to Bumpstick about replacing the whole thing. I do believe that the clunking is only from the in and out play though. If I sit inside, and have someone pull the axle in and out, it is the exact same sound. Also if I grabbed ahold of the tire, and shook it, it would make the sound. I have a pic of the other side now. It looked totally different than I thought it would, so is it gov-loc? The carrier was lined up just the way the first pics show, when I pulled the pan.
Here's the pic of the other side...
  #25 (permalink)
Old 12-07-2005, 09:30 AM
s10 axle play
Axle end play is normal. Don't be alarmed by having it. A small trick to eliminating the play would be to ensure that the bearing surface is good. Look for any pitting, grooves, loss of metal. If it is good you can simply put a small tack weld on the end of the axle and grind it down to the necessary clearance. Any questions you can give me a call. 916-922-5297.
  #26 (permalink)
Old 12-07-2005, 11:53 AM
AMDAP's Avatar
How much end play is acceptable?
  #27 (permalink)
Old 12-07-2005, 01:32 PM
Originally Posted by AMDAP
That is a Gov-lock. Under "normal" conditions it will act just like an open diff. If one wheel starts to spin more than about 100rpm more than the other it will lock solid. It will also unlock at a certain mph (I don't remember what it is but 40mph sounds right). They are known for going BOOM! when they lock and taking out the entire rear end with it.
1/4" of play is too much. I don't remember seeing any exact spec but I would guess any more than 1/8" is too much. If there is too much play you risk the c-clip coming out and loosing the entire wheel/tire/axle...not fun!
  #28 (permalink)
Old 12-07-2005, 04:35 PM
AMDAP's Avatar
Thanks Triaged! That is what I figured. I don't want my grandmas wheel passing her on the road. I've been looking for junked s-10's on the island, but I'm not finding anything yet. So I guess I better figure out how to fix this thing...
  #29 (permalink)
Old 12-07-2005, 08:03 PM
Bumpstick's Avatar
Hammer and a torch
AMDAP... (figured it was a gov-lock) I would just consider replacing it with either an Eaton unit or to go cheap just get an open carrier and replace it till your ready to invest the $$$...
If you go the open carrier route just change over your ring gear and get new carrier bearings and shim in the new setup and your done...
  #30 (permalink)
Old 12-07-2005, 10:52 PM
AMDAP's Avatar
In theory could I just swap over the shims that are already there? I would love to learn to set-up gears though. That is the next thing I need to learn. This has just got to hold her over for a while. When I get it, I want to put a 9" in there. So the cheapest solution right now is the best solution. Thanks!
Engine stalling problem JamesRS Engine 3 01-30-2006 12:22 PM
Ignition Problem malibuman66 Electrical 17 01-24-2006 02:05 AM
cv axle boots replace or buy new axle? catscan4free Transmission - Rearend 20 03-05-2004 09:25 PM
gm 10 bolt axle, bearings. hepcat Transmission - Rearend 4 09-20-2003 09:36 AM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 06:18 PM
