S-10 Blazer 4.3 Tbi To Carb ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2008, 10:31 AM
K-1's Avatar
K-1 K-1 is offline
K-1
Can I Slide A 4.3 Tbi Into My 87 Blazer. What`s The Process To Change It To Carb ? Can I Do Headders ?
Old 09-24-2008, 11:30 AM
DoubleVision's Avatar
You`ll need a intake that accepts a carb, a fuel pressure regulator to get the fuel pressure down to around 5 psi. a distributor that has mechanical as well as a vacuum advance. Sure you can do headers, but when I looked into them for mine the cheapest set I found was $300, but now for some reason they go for much less. If your looking for performance out of a 4.3 then you should start with a 1996 and newer Vortec 4.3. The older one`s have horrible swirl vane heads on them and run out of breath at 3500 rpm. But don`t be confused here either, GM started using the name "Vortec" in the 80`s, but the real Vortec`s came in 1996. Or you can get a older 4.3 and bolt on 96 and later vortec heads, you`ll need custom studs as they came with "net lash" valves that are non adjustable. Then you just add a vortec intake which is around another $300. Sure you can tap into the performance side of a 4.3, but it`s not cheap as I already learned.
Gm Tbi To Carb bigC Transmission - Rearend 5 12-02-2007 06:24 PM
TBI or Carb fusion116 Hotrodding Basics 1 08-22-2007 07:17 PM
Brake lights switch oldsmo Electrical 4 10-19-2006 12:23 PM
wiring a v8 up in a s 10 blazer wolfinwv Electrical 5 01-22-2006 03:11 AM
Blazer S10 4.3 idles poorly bigjack Engine 1 03-30-2003 09:38 AM
