S-10 Blazer Tranny/T.C. Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2011, 10:39 AM
My 1999 S-10 Blazer came with a 4L60E and NP1 T.C. , I found a 4L80E from a 2001 S-10 ZR2 Truck. Will this swap be bolt in or is it going to be an issue like I see the full size truck guys having troubles with?? ( splines, length, pins etc.) I am hoping that both vehicles being S-10's, everything should match up? Anyone know what transfer case comes with that stock 4L80E on the ZR2's?
Thanks in advance!!
Craig
Old 11-05-2011, 11:38 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I have not seen a 4L80e installed in any OEM S-10 truck, I certainly have not seen it all though. .
The 4L80e and the 4L60e transmissions are not direct swappable because of length, splines, wire harness pin locations and PCM programing
2wd tranny in 4wd blazer jasondg99@yahoo.com Transmission - Rearend 3 08-04-2011 06:02 PM
1998 blazer tranny blew can I swap engines disice1011 Transmission - Rearend 1 12-04-2008 01:31 AM
plz help s15 blew up. 98 blazer tranny blew cani swap engines disice1011 Engine 2 12-02-2008 09:33 PM
S-10 blazer, Tranny swap gator Transmission - Rearend 1 04-22-2003 07:03 PM
K5 Blazer tranny antirice Transmission - Rearend 1 12-09-2002 04:53 PM
