s-10 brakes to a 67 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2008, 01:09 PM
im redoing a 67 camaro with the original 10 bolt with a posi and like people say dont want to spend alot for the conversion and was wondering if a 98 s-10 im pretty sure its 4wd, rear disk brakes would bolt onto the camaro...and also anyone whos heard anything good about the hotchkis suspension system for that car...
Old 02-24-2008, 10:30 PM
Wiki Edits: 27
cad brakes
I have seen cad eldo rear disc's put on ...You an make or buy the mounting brackets
Old 02-27-2008, 02:04 AM
Your Camaro should have the same trapezoidal 4-bolt backing plate flange that the newer (post about 88) S10's have. I don't know if the backing plate flange to axle flange distance is the same.
79 camaro swap power to manual brakes jsteve068 Suspension - Brakes - Steering 4 02-18-2006 07:00 AM
Removing Power Brakes from 70 Camaro Rick Beil Suspension - Brakes - Steering 3 10-06-2005 08:19 AM
Will power steering box from 82 camaro work in 67 el camino dave2148 Suspension - Brakes - Steering 7 09-05-2005 09:37 PM
67 camaro rearend 72 Z28 Transmission - Rearend 2 02-09-2004 06:53 PM
will 68/69 GTO disc brakes fit 67 camaro 67454 Suspension - Brakes - Steering 3 12-18-2003 09:07 PM
