S-10 Braking Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2012, 06:12 AM
After multiple power break burnouts at the 2012 Woodward Dream Cruise. My Son's S-10 Xtreme with a 350 V-8 we installed has a very soft break pedal. We bled the rear passenger side brake to see if pedal improved. Flow was weak. Lines leading from master cylinder are very close to the headers. After crusing all day and the burnouts did we cook the brake fluid ???
Old 08-20-2012, 07:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Any time the brake fluid is boiled, there will be gas formed in the brake line(s) until it's removed. This can be due to the brake calipers or slave cylinders being overheated, or it can be due to the brake lines being too close to a heat source. This can happen quickly, too- there's no brake fluid flow, per se, like you have w/a fuel line. So the exposed line and the fluid within will quickly become overheated.
In your case I would recommend you drain/replace all the fluid in the event it was damaged by the overheating.
You need to use a reflective barrier and/or a
 Brake Line Heat Shield Sleeve Brake Line Heat Shield Sleeve
between the heat and the brake line.
Consider installing a line lock to help doing water burnouts if dragging the brakes is causing overheating of the calipers/wheel cylinders. And if the brakes have gotten that hot, I'd go in and do a close inspection of the bearings and seals. Replace as necessary and in any event replace the grease.
1986 chevy braking problems closson1984 Hotrodding Basics 6 05-06-2012 08:17 AM
hissing when braking cutthroatkid Engine 4 02-19-2012 08:05 PM
Braking hell... help bearpaw Suspension - Brakes - Steering 12 08-24-2010 08:42 PM
braking and steering? zcxtmi Suspension - Brakes - Steering 2 07-11-2006 11:40 AM
power braking 85stang Transmission - Rearend 9 10-25-2003 10:23 PM
