S-10 chevy rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2006, 03:42 PM
oldskools10's Avatar
Voices tell me to do this.
S-10 chevy rear end
I am looking for a stout rear end to install in a 85 S-10 with a small block and a built 700R4.The 7.8 is not gonna get it too much longer.Anybody got any suggestions? Need brake info too if anyone knows! Really don't want to tub or back halve if I don't need it as this is gonna be a street car for my 16 year old.
Old 02-18-2006, 08:12 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Look to the later S10s. They had the 8.5" rear with discs. I think the frames are the same, so it should be a bolt-in
Old 02-18-2006, 08:26 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
The later 8.5's are a direct swap for bolting in, BUT, the widths are not the same.
I've seen that any S-series with the RPO ZR2 has the 8.5, these are a huge step up from the 7.625.
Old 02-19-2006, 10:33 AM
Thanks for the info guys. I will look into a later model rear after taking some measurements of what I have.
Does anyone know a place to get build codes for this? It would make life easier if I know exactly what to ask for. Thanks in advance!
Old 02-20-2006, 12:02 AM
Some common options
1) Ford 9"...you can even get a brand new one ready to bolt in if you want to pay for it
2) Ford 8.8" Can be had with disc brakes & 31-spline axles...you just have to change the bolt pattern and it will be a bit too wide.
3) S10 8.5" 10-bolt (what I did)
They came in 96-up p/u's and Blazers. If you want it the same width you will need to get one from a 2wd. 4wd axles are 4" wider than 2wd and the ZR2's are another 4" wider than the 4wd. What you need to get one from a 96+ 2wd with 4.3L H.O. V8 and a stick. If you want disc brakes get it from a 98-up Blazer.
As long as you get the 2wd axle will be same width as you have now. For me it wasn't a direct bolt in because I had to have my drive shaft shortened by about 1".
Old 02-20-2006, 03:01 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
The 8.8 is a darn near drop in and go swap from an Explorer.
Clicky HERE for the Explorer axle swap info.
Old 02-20-2006, 11:52 AM
curtis73's Avatar
Wiki Edits: 16
And the 8.8 came with discs for many years. Its also pretty stout... its more or less a copy of a GM 12-bolt.
Old 02-20-2006, 12:56 PM
58Chev's Avatar
Building a 10 footer.
Last journal entry: No more room in my garage.
From 95+ for disk brakes.
Old 02-20-2006, 01:12 PM
Thanks for linking my write-up
The 8.8 is a great rear to use. I've put it into action at the track this season with my 350 S-10 and it's doing great. The only real drawback I see is that because it is a decent bit wider you need to find some large backspaced wheels to run wide tires, but I was able to find some 6"BS 10 inch wheels to mount my 10in slicks on which set them in to a pretty good position. Check out my write-up linked above and you will have a good idea of what to expect.
10 Bolt Rear End TORI1 Transmission - Rearend 1 12-29-2005 01:02 PM
71 chevy truck rear end choppy71 Transmission - Rearend 14 09-23-2005 02:55 PM
Rear End Axle Code for the Chevy S -10's Traps Restoration Transmission - Rearend 1 02-27-2005 11:05 PM
Chevy rear end wobbles. whoohaadan General Rodding Tech 3 03-04-2003 10:03 AM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
