S-10 , convert 2wd to a 4x4 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2012, 12:56 PM
i have a 1985 s10 truck 2.5 with 4speed that is 2wd at the time and am wantin to make it 4wd and i dont know were to start lol
Old 09-12-2012, 07:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders.
I edited the thread title since "need help" does not offer a clue to what your question is.
Moving to basics forum
Old 09-12-2012, 08:01 PM
LATECH's Avatar
I had an S 10 years ago and was going to do the same thing. I sold the project when I moved back to florida at the time.
I got a jeep front axle a dana 44 I think, the width was almost perfect for building shackles to hook it to the frame in the front.
Also i got a dana 20 transfer case( IIRC thats what it was) and it was a divorced mount case. it had 3 driveshaft yokes on it, and a massive spot for mounting it on a bracket.
Sounds like a real cool and fun project .
I would think the 4 cylinder would be OK as most 4 wheel action is slow moving, and gear reduction is your friend.(low range)Could be a way cool crawler.
Fact is stranger than Fiction
Old 09-12-2012, 10:11 PM
if you can fab swapping in a solid axle and making some brackets for a divorced tcase then some drive shafts and steering and you are good to go. i just acquired a np205 divorced for a mud truck i want to build i am wanting to start with a 2wd ranger, cheaper and easy to find i already have the running gear i have a king pin 60 and d70 combo with the divorced np205 it should be fun.
first things first can you weld, whats your budget, what is the use etc....
Can I use a 4x4 master cylinder on a 2wd?? lizardking7750 Suspension - Brakes - Steering 4 01-03-2011 09:25 PM
2wd t0 newer 4x4 chassis granda's c20 Hotrodding Basics 1 11-24-2010 04:24 PM
converting from 4X4 to 2WD fred56 Transmission - Rearend 4 10-29-2007 06:12 AM
Convert 4wd th400 to 2wd? ghinmi Transmission - Rearend 8 06-06-2007 07:12 PM
2wd to 4x4 700r4 QUINTANA64 Transmission - Rearend 7 04-05-2006 06:20 PM
