Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S-10 door hinges
Old 04-30-2006, 08:33 PM
baddbob baddbob is offline
I agree with Brian, repair the old hinge if at all possible. Pull the pins and the door off the truck. Take a comparison measurement off the other side to the pin hole and try and get the bent hinge into alignment, you'll need to trial fit the door probably a few times before it's right but popping the door on and off gets easy after the first two times. GM sure screwed it up for the techs when they went with this design. Bob
