-   -   S 10 frame to fit on 62 ford falcon (http://www.hotrodders.com/forum/s-10-frame-fit-62-ford-falcon-232248.html)
Rolland 04-26-2013 01:34 PM
Has anybody done this what is the cheap and easy
poncho62 04-26-2013 02:47 PM
It isnt cheap or easy....A Falcon is a unibody....You would have to cut out the whole floor and build from scratch.....not for the beginner.
Actionjk 04-26-2013 08:48 PM
Mustang II will fit right under your Falcon,and do away with the shock towers
h0trod 04-27-2013 11:29 AM
i have contiplated this for a long time.
i have a stock 62 falcon and a
63 falcon thats on a 71 international chassis 4wd.
cheap and easy? (insert non stop laughter here)
however, the easiest way to go about this, is to
gut the entire car,
weld support bracing into the cab or body
weld doors shut
cut off all unibody substructure
purchase rear frame rails from summit, or other parts place that are ment for GM F bodys.
purchase 2 x 3 box tubing
and either a mustang II kit, or a straight axle.
either way, its a big project.
NEW INTERIORS 04-27-2013 01:05 PM
MAN !!!!!!:drunk:
What is it about these S-10 frames that everyone want's to put one under their hotrods ????:drunk::pain::pain::pain::pain:
Just up grade what you have or build a whole new frame... THAT is a lot better then trying to swap a S-10 Frame under it...
h0trod 04-27-2013 01:59 PM
Originally Posted by NEW INTERIORS (Post 1670644)
MAN !!!!!!:drunk:
simply, because they have no clue.
