S 10 frame to fit on 62 ford falcon - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2013, 01:34 PM
Has anybody done this what is the cheap and easy
Old 04-26-2013, 02:47 PM
poncho62's Avatar
Wiki Edits: 5
It isnt cheap or easy....A Falcon is a unibody....You would have to cut out the whole floor and build from scratch.....not for the beginner.
Old 04-26-2013, 08:48 PM
Mustang II will fit right under your Falcon,and do away with the shock towers
Old 04-27-2013, 11:29 AM
if you beat my boat, well race
i have contiplated this for a long time.
i have a stock 62 falcon and a
63 falcon thats on a 71 international chassis 4wd.
cheap and easy? (insert non stop laughter here)
however, the easiest way to go about this, is to
gut the entire car,
weld support bracing into the cab or body
weld doors shut
cut off all unibody substructure
purchase rear frame rails from summit, or other parts place that are ment for GM F bodys.
purchase 2 x 3 box tubing
and either a mustang II kit, or a straight axle.
either way, its a big project.
Old 04-27-2013, 01:05 PM
life is a temporary assignment
MAN !!!!!!
What is it about these S-10 frames that everyone want's to put one under their hotrods ????
Just up grade what you have or build a whole new frame... THAT is a lot better then trying to swap a S-10 Frame under it...
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
Crosley (04-27-2013)
Old 04-27-2013, 01:59 PM
Originally Posted by NEW INTERIORS View Post
MAN !!!!!!
simply, because they have no clue.
s10 frame to fit 41 willys coupe bgatlin123 Hotrodding Basics 3 08-05-2012 08:59 AM
will a 40 chevy truck fit on a S-10 frame 71corvette Hotrodding Basics 11 12-07-2008 07:39 PM
28 body doesn't seem to fit the frame oldguy829 Body - Exterior 17 11-28-2007 02:39 PM
will a 1969 ranchero fit in a 1965 ford falcon or will i need to modify 1965fordfalcon Transmission - Rearend 7 03-04-2006 06:37 PM
Windshield Frame doesn't fit - help 30 sportcoupe Body - Exterior 4 01-05-2003 02:41 AM
