-   -   s-10 manual trans question (http://www.hotrodders.com/forum/s-10-manual-trans-question-139469.html)
ds-unique 05-28-2008 06:05 PM
Has anyone put a s-10 transmission behind a chevie 350. If you have, what clutch and pressure plate combo did you use. Also did you have to do anything different to the throwout bearing and fork.We have a early model transmission 84-85 with a 14 spline imput shaft. This is bolted to an early model bellhousing about a early 70`s i think. Also what slave cyclinder to use on out side bellhousing. :confused:
OneBadBoo 05-30-2008 02:28 AM
Bellhousing
Hi....If your going to use a slave cyl. use th newer Bellhousing and 1/2 ton clutch.......
Blazin__ 05-30-2008 09:20 PM
why dont you just put in a T5 and get the clutch to match
