s-10 manual trans question
Has anyone put a s-10 transmission behind a chevie 350. If you have, what clutch and pressure plate combo did you use. Also did you have to do anything different to the throwout bearing and fork.We have a early model transmission 84-85 with a 14 spline imput shaft. This is bolted to an early model bellhousing about a early 70`s i think. Also what slave cyclinder to use on out side bellhousing.
Bellhousing
why dont you just put in a T5 and get the clutch to match
| 65 skylark turbo 400 trans. install question | skylark65 | Transmission - Rearend | 7 | 05-09-2007 09:29 PM |
| another 10 bolt question! | ap72 | Transmission - Rearend | 5 | 04-18-2007 08:35 PM |
| Manual trans cooler? pump related | beemdubya | Transmission - Rearend | 3 | 06-06-2005 12:15 PM |
| G-body Manual Trans Conversion | madhat | Transmission - Rearend | 6 | 04-27-2005 02:22 AM |
| stuck drain plug on manual trans | steffan_miller | Transmission - Rearend | 5 | 07-01-2004 10:15 AM |
