Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - s-10 manual trans question
Old 05-30-2008, 03:28 AM
OneBadBoo OneBadBoo is offline
Originally Posted by ds-unique
Has anyone put a s-10 transmission behind a chevie 350. If you have, what clutch and pressure plate combo did you use. Also did you have to do anything different to the throwout bearing and fork.We have a early model transmission 84-85 with a 14 spline imput shaft. This is bolted to an early model bellhousing about a early 70`s i think. Also what slave cyclinder to use on out side bellhousing.
Hi....If your going to use a slave cyl. use th newer Bellhousing and 1/2 ton clutch.......
