S-10 oil lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2006, 02:20 PM
S-10 oil lines
Ive got a 93 s-10 Blazer with the 4.3 v-6 motor. this thing is also 4 wheel drive. The oil lines from the oil filter(located behind the left front head light) started to leak, so I thought I'd change them. You gotta be kiddin' me . What a pain. The two lines have a flange at each end. The problem is that there is a bar running from the bottom of the transmission to the motor mount , and this bar prevents you from removing the oil lines. Disconnenting this bar at one end does no good, and you can't get to the other end. It almost looks like you have to break the motor mounts loose and jack the motor way up to get at this bar(bolted to one of the bolt holes on the block for the motor mounts) , then remove and replace the oil lines. Has anybody else had to do this? Is there an easier way to replace these lines. I could really use some help here!!!!
Norm
Old 04-22-2006, 07:19 PM
Vortech 4.3's Avatar
jack of all trades
here is your help. i've done a lot of them.
take the engine mount bolt out. jack up the engine on that side, BE CAREFULL !!!
take the bracket out. then the lines will come out easy.
Who makes the best oil??? classic_chevy_guy Engine 28 02-21-2013 08:04 PM
new engine, oil pressure probs montea Engine 35 06-02-2006 12:37 PM
Radiator Oil Cooler Lines holes jesse01 Engine 6 04-17-2005 05:38 PM
i have a 1961 chevy apache 10 does anyone know what metal my brake lines are? 61ChevyTruck Hotrodding Basics 4 03-30-2004 12:03 PM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
