S-10 Proportioning Valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2003, 07:51 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post S-10 Proportioning Valve
I am putting together the brakes for my S-10 and I have some questions. First, it was an original manual disk/drum setup. I converted to a Ford 9" rear with factory disk. I am also running 18.5x33 Rear tires and P165 up front. It is a drag racing setup.
Will the original Prop. Valve work? It is a distribution block/valve right at the master cylinder. I have heard that the disk require a smaller amount of pressure than drums and the rear change out can cause the rear brakes to lock. That is why I listed tire sizes. What do you all think?
Thanks,
Chris
Old 01-02-2003, 06:02 PM
Post
Chris,
You must change the master cylider to one originaly used with 4 wheel disc (corvette) or remove the residual check valve from yours. I always run a vette MC. I had a pro street 34 with 4 w disc NO proportioning valve and had no problems with wheel lockup. A 31 sedan same setup No problems. And building a 31 coupe now same setup. You will probaly just have to experiment with yours. If any thing I would think the front would want to lock before the rear (less resistance).
Later, Mark
Old 01-02-2003, 07:28 PM
TurboS10's Avatar
Wiki Edits: 2
Post
Okay, I am going to have to plead stupid. Is the block beside the master cylinder a residual check valve? I was under the impression this was a proportioning valve. Same thing?
Thanks,
Chris
Old 01-02-2003, 08:24 PM
BOBCRMAN@aol.com's Avatar
Post
it is called a multipurpose valve, it turns on the brake lite , does the brake bias-proportioning, residual valve.
Old 01-03-2003, 01:50 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Smile
Chris,maybe there is rules for brakes,I changed my coupe to manual four wheel disc I didn't have room for a booster had to go with a small bore master cylinder to get the pressure to work the brakes,if you got room for a booster put one in and as mentioned a m/c from a four wheel disc.
Old 01-03-2003, 10:42 AM
TurboS10's Avatar
Wiki Edits: 2
Post
[quote]Originally posted by zonk:
<strong>Chris,maybe there is rules for brakes,I changed my coupe to manual four wheel disc I didn't have room for a booster had to go with a small bore master cylinder to get the pressure to work the brakes,if you got room for a booster put one in and as mentioned a m/c from a four wheel disc. </strong><hr></blockquote>
I cant run a booster. The engine is turbocharged, so it will not work.
Chris
