Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S-10 rearend for a hotrod?
Old 12-30-2012, 06:01 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
SN95 brakes require an after market caliper bracket to work on the FOX rear end due to the difference in the axle hang out. You can use '94 to '98 SN95 axles in the FOX housing and get 5 lugs and the disc brakes will be a bolt on, but the over all width will increase slightly. SN95 axles and brakes from a V6 car with the 7.5 rear end will fit the 8.8 FOX rear end.
