S-10 to Rolls Royce graft - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2010, 07:01 PM
I inherited a 1959 SC I Rolls Royce. With a lot of help we grafted the front clip (suspension/steering/engine/transmission) in place of the 55 year old Rolls Royce systems. We also modified the rear-end into the Rolls Royce - so we have a 1997 Chevrolet underneath a really nice old car. We even have ABS ! The car sits well and is fine on the road. Now i need to get the Chevy factory suspension to lighten up and become much softer/more luxurious. That is why i joined this Bulletin Board. I could really use some help on this important part of the project. Thanks !
Old 12-03-2010, 02:09 PM
39Hemi's Avatar
The first thing that comes to my mind is convert to an air ride system. With the stock gm components you now have under the car it should be simple switch and you can tune the ride to what you want.
This sounds like a really cool project, got any pictures?
Old 12-06-2010, 06:39 AM
Don Meyer's Avatar
I put a RR on a G body frame. I'll have to dig into my records to see what sprins I used.
Don
Old 12-06-2010, 04:19 PM
Here is the Chevy engine in the Rolls Royce engine bay !
s
ID:	50637   Click image for larger version
ID:	50638   Click image for larger version
ID:	50639   Click image for larger version
Old 12-07-2010, 01:31 PM
Don Meyer's Avatar
There certainly is no room lef in the engine conpartment . For the front springs I used 76 cad seville. I have not been able to find what springs I used for the rear.
ID:	50664   Click image for larger version
Old 12-07-2010, 01:41 PM
modern RR
tell me more about your RR project !
Old 12-07-2010, 07:00 PM
Don Meyer's Avatar
Did youhave to raise the rear floor? Does the car sit at normal ride ht?
My specs:
350/700r4/9"
Global west cotrol arms
new wood/leather/gauges
ID:	50666   Click image for larger version
ID:	50667   Click image for larger version
Old 12-08-2010, 06:16 AM
the car looks entirely stock, except i removed the antenna
it was my Mom's car and i restored it/modernized it so my 3 brother's (none are mechanical and 2 are hard on cars) would be able to use it without hassle. Alston Race Car did the Chassis work and McCabe did the bodywork. Then the local shop can take care of the car !
Old 12-08-2010, 07:30 AM
Don Meyer's Avatar
I'd be interested on pics of the chassis work . I'd also like to see a side pic of the car to see how it sits.
Thanks Don Meyer-
Old 12-08-2010, 10:55 AM
side views....
i will get under the car over the weekend for Chassis shots.
Old 12-09-2010, 05:35 AM
photo's
we figured it out and here they are. sorry for the delay.
steve
ID:	50699   Click image for larger version
ID:	50700   Click image for larger version
ID:	50701   Click image for larger version
Old 12-16-2010, 09:40 AM
chassis shots
finally - proof that it is truly a Chevy !
ID:	50885   Click image for larger version
ID:	50886   Click image for larger version
ID:	50887   Click image for larger version
Old 12-16-2010, 09:59 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
those cars are just flat-out cool
Swaping 10 bolt rear ends, what will fit? fansick Transmission - Rearend 5 07-13-2007 02:41 PM
7 deg versus 10 degree ? Guy Hiltz Engine 3 10-29-2006 01:05 AM
Brake lights switch oldsmo Electrical 4 10-19-2006 11:23 AM
unusual 10 bolt GM diffy off '75 SW... paulo 1 Transmission - Rearend 2 08-16-2006 08:10 PM
Engine Vacuum is showing 10 and no higher? ataririder Engine 42 02-18-2003 07:12 PM
