Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S-10 Steering Sustitutes
Old 01-11-2012, 08:11 PM
StreetKruzer StreetKruzer is offline
Last journal entry: Finally some floor!
Thanks For The Reply C-cab
Yes, Need To Lighten The Front As Much As Possible. As Far As Changing Steering To A R & P, Would Luv To But: I Channeled The Front Of The Body About 4 Inches Over The Frame Which Will Make It Even More Of A Challenge To Get To The Box On The Rack Because A Straight Line From The Steering Column To The Rack Would Pass Directly Thru The S-10 Suspension Just Inside Of The Coil Spring, Below The Top A Arm And Above The Bottom. Too Much Gyration For U-joints. Back To The Drawing Board For Me. Perhaps I Do Another Season Or Two With The S-10 Front & Then Bite The Bullet And Cut It Off!
