S-10 trans problem/question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2006, 11:04 AM
Jmark's Avatar
Friend just called me and asked about his truck. '97 S-10 4 cyl automatic.
Truck has approx. 50,000 miles and the trans has already been done once before. He got it a few months ago.
Said he has reverse, first is good, shifts to second and holds good, then thats it. No third or fourth. Says if he accelerates hard in second it does finally go into "something", as he put it. Maybe lockup? I dunno. In normal driving, there is nothing past second gear.
I was thinking broken sun shell but he DOES have reverse so I guess that rules that problem out?
Its been fine up until yesterday, then it just lost 3 and 4 all of a sudden.
This guy drives like a little old lady so hotrodding is not a possibility.
I called my son to see if his scanner could ck the trans but he doesn't have the tranny modules.
Short of having it towed to a trans shop, any ideas?
Thanks.
Mark
Old 05-17-2006, 02:24 PM
airworld2's Avatar
s 10
3-4 plates are burnt, thats what it sounds like and most likely.
Old 05-17-2006, 02:31 PM
ztoy's Avatar
speed freak
Seems like I remember when my tranny in my 92 went out I lost 3 & 4 and the guy told me they both us the same band so they get twice the use. Had to get a rebuilt one.
Old 05-17-2006, 05:03 PM
Jmark's Avatar
Thanks Airworld..(don't know you real name :-).
Question. What would cause the 3-4 pack to burn up so quickly if it was in fact recently rebuilt? This guy drives so conservatively its pathetic. If he has it re-done again, is there something that can be done to help it last?
and for Tony,,,, Any recommendations on a good shop in central phoenix? Maybe close to 24st and Indian School area? (I don't think i'm quite up to the task of doing someone else's tranny quite yet! LOL)
Mark
Old 05-17-2006, 07:16 PM
Crosley's Avatar
Wiki Edits: 1659
3-4 clutches have been a problem since day one on these trannys.
Why did it burn up so quickly after a rebuild? The re-builder replaced parts and did not adress the problem/cause .
Shop recomendation? I cannot help there.
sorry
Old 05-17-2006, 08:40 PM
Jmark's Avatar
Thanks Tony. He's going to contact the seller and see who did the trans last. Maybe he'll get lucky! LOL Really a shame to have it take a dump so soon after being re-done. Such is life I guess.
Maybe I'll call Transtar and see who they may recommend.
Mark
Old 05-17-2006, 09:27 PM
airworld2's Avatar
s10
soap box, check
some times the builder doesnt get the credit he is do, building the transmission is not the whole job, case in point my own shop truck my fathers 96 chevy 5.7 4l60e I built the tranny at 75000 miles almost 6 years ago after he passed away. about 8 months ago it started shifting soft and slipping when it shifted but I ignored it, well last week no 3rd no 4th. well after another rebuild done by yours truly
slip shifting,after kicking myself wondering what didnt I do replacing line pressure componets, well to make the point it wasnt the tranny but the computer causing low line pressure and that caused transmission failure
but if you cant control the quality of your work parts dont matter
how does the unit work after the rebuild that what matters
some shops work just to get the job out the door and getting the money ,some want to get it done right
Old 05-17-2006, 10:43 PM
Jmark's Avatar
I guess that's the problem we are facing in finding a good shop that will cover all the bases and do the job so it lasts a little longer this time.
Does the 60e have a TV cable? or is it all by computer and throttle position? Wish I knew more so I could be more help. sigh.
Old 05-18-2006, 06:35 AM
tnsmith10's Avatar
when will it rain???
no t.v. cable on a 4l60e. all electronic control
Old 05-18-2006, 02:30 PM
Jmark's Avatar
Two last questions before I call my friend back.
1. He recently told me that when he checked the fluid, it was about 3" ABOVE the full mark, running in park. Could this cause the above problem?
2. Is there a way to check the computer to see if its sending the correct info to the trans for pressures?
I hate to see him sink a ton into it only to have the same thing happen 4 months down the road.
Thanks
Mark
Just talked to my friend and told him the probably bad news and guestamated a cost of atleast $1500. He's leaving for a month vacation back east soon and is going to park it for now, too much money. He just went through forced retirement from Motorola and then was denied dissability for 2 years on conjestive heart failure. Trying to figure a way to sneek over while he's gone and pull the tranny and give it a shot!
Old 05-18-2006, 09:17 PM
airworld2's Avatar
s 10
snap on scanner with tranny trouble shooter for the info,best advise find another drum from a core supply loaded and ready to go with good plates.install new valve in pump for increased line pressure and line pressure solenoid. along with the rebuild
Old 05-23-2006, 07:03 PM
Jmark's Avatar
Well, I had the opportunity to drive my friends truck today. He had called and thought maybe it wasn't messed up but since this is his first automatic, he wasn't sure on the shifting????????????????????????
Anyways, it does wind up more than normal between shifts but does have all 4 gears and L/U. Probably because its a 4 banger and needs to stay up in the power band more,,,,, I dunno,,,,, but it does work ok.
Mark
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
Trans Down Shifting 71gtx Transmission - Rearend 0 04-15-2004 06:33 AM
Tranny help in a 79 Trans Am BudLight Transmission - Rearend 2 04-13-2004 08:01 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
10 0/0 theory dinger Hotrodders' Lounge 3 09-12-2002 08:14 AM
