S-10 V8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2003, 11:12 PM
New Member
Post S-10 V8
a friend of mine has a s-10 with a 350 in it and is using the stock rearend but needs a posi to get some traction. So what will work without changing the whole rearend axels and all. What can u interchange with them to make it a posi.
Old 04-07-2003, 11:37 PM
bonuts's Avatar
Got Ouzo for touzo
Post
You can get a spool, but I wouldn't if your buddy uses his as a daily driver like I do mine. Another idea is the S-10 4X4's some had posi's from the factory. I had one in my truck but they are a little wider than the truck rear ends. Then I twisted an axle so they're not all that strong. They mount the same as the 2 wheel drive trucks.
bonuts
Old 04-09-2003, 08:28 PM
New Member
Post
can u interchange the gears out of another vehicle that will go into the s-10 housing without modifing it and being a posi
Old 04-09-2003, 08:56 PM
bonuts's Avatar
Got Ouzo for touzo
Post
My dad was saying it could be possible to swap out the two S-10 rears. (the 4X4 one, and the 2 wheel drive). I don't know if they're the same, but I'd be interested in finding out. If so the posi units are out there in 4x4 S-10's. Took a while to find the one I had though.
bonuts
Old 04-10-2003, 03:23 AM
New Member
Post
in the 4x4's r they limited slip or r they posi.
