-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   S-10 V8 swap Fuel pressure regulator question (http://www.hotrodders.com/forum/s-10-v8-swap-fuel-pressure-regulator-question-121055.html)
Andrew7dg 07-28-2007 11:42 AM
I am going to use the stock tank with fuel pump on my 88 s-10
In the V8 swap manual (JTR) it mentions that I need a part from GM for the return line and that part is kind of expensive. However I was browsing around and found this...
http://www.s10v8.com/store/product_i...products_id/49
which doesn't use this special GM part...
So I am confused...
I have the regulator so I am half way there. Can I buy a hardware store 90 degree and make this work?
Deuce 07-28-2007 01:43 PM
http://www.s10v8.com/store/images/bypass.jpg
I have never done this swap ... but if you have a regulator ... it looks like simple plumbing to me ... :D
I have done a good bit of hard line plumbing in my years ... and I also recommend you installing a external fuel filter ...
http://hotrodders.com/journal_photos...1772822712.jpg
Vortech 4.3 07-29-2007 09:15 AM
Deuce
is that the drive shaft in that pic ? with dents in it.
1ownerT 07-29-2007 10:17 AM
Originally Posted by Vortech 4.3
Deuce
That is the exhaust.
Deuce 07-29-2007 11:38 AM
Deuce
Thanks 1ownerT :D
http://hotrodders.com/journal_photos...1772828871.jpg
The stuff with the " dents " is actually Chambered exhaust pipes. Chambered exhaust systems originally came on Corvettes with side pipes and 69 Z-28's. I had previously owned Corvettes and Z-28's and like the " sound " so I used that type of system on my 32 3W coupe project. They also are round and easy to install on a 32 chassis where room is at a premium . They also are easy to mount high enough that they do not drag or be seen seen from a side view.
:thumbup:
Vortech 4.3 07-29-2007 08:03 PM
ahhh, i see. looks good.
