Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S-10 V8 swap Fuel pressure regulator question
Old 07-28-2007, 11:42 AM
Andrew7dg's Avatar
Andrew7dg Andrew7dg is offline
I am going to use the stock tank with fuel pump on my 88 s-10
In the V8 swap manual (JTR) it mentions that I need a part from GM for the return line and that part is kind of expensive. However I was browsing around and found this...
which doesn't use this special GM part...
So I am confused...
I have the regulator so I am half way there. Can I buy a hardware store 90 degree and make this work?
