S-10 V8 & transmission conversion questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2012, 05:56 PM
v8 s10
ok so i got a 95 ext cab s10 i also got a 95 z71 with a 350 and 4l60e trans i wont to put the 350 in the s10 i got the motor months and the headers ?number1 is what else do i need for the swap??? sec?? can i take the transfor case off and put a 2wd tailshaft on it?
Old 06-15-2012, 10:10 PM
joshp83's Avatar
owner of Prices Garage
u can swap the out put shafts u got to remove the drums inside the tranny to get to it why dont you use the s10 tranny it would make things easier
Old 06-16-2012, 12:55 AM
ronbuhg's Avatar
If I may put my 2 cents in here.joshp83 is correct on his advice.. I have an 85 S10 w/SBC, But I couldnt use the original trans only because it had the 2.8 which is a totally different bellhousing pattern...I suggest you get the S10 V8 conversion manual from JTR Publishing ,P.O. Box 66,Livermore,CA., 94551, or order it from summit racing, Im sorry I dont have their part #, but I do have a website for ~~www.V8S10.com~ I highly recommend this manual, it was a huge help even though I bought my truck with the SBC already in it. very useful to show me what I needed to correct the right way ! Good luck & let us know how it turns out.note ~~ the book I got was the 15th printing & published in Jan. 2004. but it should still be relevant for your use
Old 06-16-2012, 08:01 AM
joshp83's Avatar
thats a very good book got it in my shop the 2.8 had a small bell housing and converter the 4.3 shared the v8 bolt pattern and the dust cover is narrower wich gives more clearenence
