S-10 Wheels on an early Chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2008, 02:13 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I have decided to use those 15x7 aluminum 5-spoke wheels on my 66 Elky.
I bought a set of the base s-10 wheels for temporary use and had to grind some nubs off from the center hole to get clearance for the hub and rear axel.
Now that I know I will need to machine the hubs and axle flanges to get them to mount, I am needing to get over another issue.
I will want to use the factory s-10 caps on the wheels. (98+ type wheels)
So----will I need to change all of the studs to use the metric nuts that the factory caps will need for retention?
Or----is there a 7/16 version lugnut available that has the outer threads to retain the cap??
Axle has to come out anyway to reduce the dia of the drum locating hub (will leave enough to center the drum) so changing studs would not be a big deal---if they are available to fit the axle and hub.
Any one done this???
Anyone have any input on this??
Bryan
Old 10-12-2008, 05:58 PM
poncho62's Avatar
Wiki Edits: 5
I have not done it, but I think I would change the studs.......the metrics seem a little beefier than the 7/16......
Old 10-14-2008, 04:41 AM
SSedan64's Avatar
Bryan
I had the same idea Bryan. I bought a set a few years ago for my 64 Chevelle. I read somewhere these rims use the center hole to locate them & distribute the load. It would be easier to open up the hole in the rim I think.
I don't have any Info about the lug nuts tho'. Haven't figured out what I'm gonna use either.
They are nice looking rims for factory.
Old 10-15-2008, 07:24 PM
Bryan59EC's Avatar
Well,
I will machine the axle flanges and front hubs to fit the wheels
Gonna give that stud changing some serious thought as well.
Hopefully---I will be able to use s-10 rotors when/if I upgrade to discs.
I think these wheels (with 205/70 tires) will look very nice on an otherwise stock appearing car.
Gonna be looking into this as soon as I return home this weekend.
Old 10-19-2008, 11:19 AM
Bryan59EC's Avatar
Went junkyardin' today and bought one of these S-10 wheels-($30)
Dirty but looks okay---I woulda bought it even if it was broken.
Got it home and guess what----slipped right onto the 65 hub I have laying about
Now if I will get up off my lazy butt and go waaaay out back, I will pull a wheel from the frame I have and see if it will fit the axel.
Have no idea why the aluminum wheel will fit and the steel wheel will not
Gonna go on a lug nut and stud search during the week
Also gonna see if the will fit the rotors I have. That old frame had a set of drop spindle discs on it and seems no one wants to buy them. Brand new too.
Old 01-31-2009, 02:50 PM
Bryan59EC's Avatar
Well, finally picked up a set of late model S-10 wheels
Went to mount them onto the car, and they would not fit.
Not to mention that all of the studs needed to be replaced with longer ones, and the "SPECIAL" 7/16 lugnuts needed to hold the center cap plastic retainer nuts.
Rather than bore the wheel center-(afraid of losing a balance reference surface), I trimmed .020 from the front hubs (except where the drums center), and kinda the same thing on rear axles.
I experimented with a partscar axle before cutting the good ones.
Hard to get a true center on the axles in the little lathe at work, so I ended up just removing everything that was not needed to center the rear drums.
Also replace thebearings - used a pair of those bearings that move the bearing and seal surfaces to an unworn position.
Bound and determined to get hese wheels on the car
I WILL be running ww tires---this is about the size tire I am going to use.
215-70-15
I think they look just fine---how about you??
Also finally got my hood goodies put back on----yep, the car is dirty.
one step at a time----it will eventually get back together
Bryan's toyz
59 ElCamino 454/TKO 5spd--(daddy)
66 ElCamino 3oh7/TKO 5spd (mousey) looks like a car again--painted 12-12-08----YAY
Chevelle 10 Bolt question again 70 ElCam Transmission - Rearend 3 03-09-2008 02:13 PM
Traction bars 428ho Suspension - Brakes - Steering 29 01-25-2007 02:31 PM
67 chevelle 12 bolt fit in 70 chevelle? 70chevelle327 Transmission - Rearend 11 09-11-2006 08:52 AM
Turbine wheels? burninrubbah617 General Rodding Tech 4 02-28-2006 03:15 PM
Wheels Wheels Wheels chevymastermind Hotrodding Basics 2 02-22-2006 07:18 AM
