?'s on a 383 stroker chevy... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2010, 05:01 PM
i looked at a 383 today, 2 pistons have uneven wear on the skirts, took it the machine shop they said there wasnt anything wroung with the bores, just to put new pistons in it and let it go, but what can i do with a 383 stroker with cast crank, rods, and 6 pistons i dont even know that they still make..... im lookn for a good hotrod motor for my sons 62' nova, it will b automatic car, the gears will b 3.73's, i have a victor jr. intake, a 750 and a 600 edelbrock performer carbs to use, and i like the sound of the eddy's performer rpm cam..... so what could i do here??????????
Old 11-06-2010, 05:12 PM
ericnova72's Avatar
More for Less Racer
I'd want the rods checked for those two cylinders, to see if they are bent.
Actually, I'd pass on the whole deal unless it is cheap enough that you can go through it and replace a few parts if needed, like a rod set or piston set.
Be aware of the special oil pan needs of the early Nova, pan interferes with steering linkage if you try to use a normal rear sump pan, pan has to be special for that chassis.
Old 11-07-2010, 05:55 AM
yeah milodon and moroso makes a good pan 4 it, the 383 short block the guy is asking $500 for it, i tried to get him down to $250 he wouldnt go for it, the way i look at it, if it needs 2 pistons you cant add them in the cost??
Old 11-09-2010, 04:58 PM
now the guy wants $700 for a block needing pistons, all cast rods and crank, 2-bolt main at that? i see $500 at the very most, they are almost as cheap to bulid as a good ole 350!!! what tha crap????
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Help with belt or serpentine system both functional and economic chevy stroker 383 Berres Engine 8 03-22-2010 04:50 PM
383 stroker question shadowsfall111 Engine 59 02-17-2010 04:15 PM
383 Stroker Question thebellman Engine 3 02-01-2007 02:56 PM
383 chevy small block stroker ZAPP59 Engine 4 02-24-2006 09:36 AM
