s/b chevy oil pump.....how do i..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2006, 03:33 PM
clanu up around the relief valve ?? I'm a ford guy, so excuse my ignorance of the belly button oil pump Always prep my oil pumps (deburr, smooth the edges, chamfer the oil passages, etc. On the pump i have in my possesion, (sb chevy) the relief plunger looks like it is held in with some sort of a press fit plug. Question here is...is this removable, to check the relief plunger travel, cleanup of the passage after it is deburred, polished etc? And if it is, is there a preferred method of retaining the new plug, (stake in place, jb weld ect )
Old 01-09-2006, 06:20 PM
BOBCRMAN@aol.com's Avatar
If you remove the bolts holding the cover plate to the main body. Look at the mating surface on the cover. Where the spring housing is, there will be a roll/solid pin. drive this pin out, towards the machined side and the relief spring/valve assembly will slide out of the bore. DO NOT mess with the valve itself. But you can chamfer the housing. Or even make anti-cavitation slots. Re-install valve, make sure it slides with no bind. Install spring. Us old Hotrodders always want to install a couple of washers for a bit more pressure!!! Not really necessary tho. Better than stretching the spring, then finding out ""OH my GAWD!! 150 lbs. OIL pressure!!"
Have fun! BOB
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 06:55 AM
Oil Preshure ve3ham Engine 9 10-28-2004 03:36 PM
Checking oil pressure after installing a new pump. WeberVette Engine 8 12-11-2003 10:34 AM
Should I change my oil? 48Man Engine 2 01-29-2003 08:28 AM
OIL PUMP NOT DISTRIBUTING OIL; ramiro Engine 5 10-10-2002 08:03 PM
