S Spring Wire? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2010, 01:06 PM
S Spring Wire?
I've stripped down the rear seat to a 1970 Cadillac. The springs are fine but I've noticed that no wire was present to hold the springs together when someone sits on the seat.
Should I install a wire upon re assembly of this seat?
Old 02-13-2010, 10:52 AM
DanTwoLakes's Avatar
Wiki Edits: 22
That is called a tie wire and connects all the springs, and yes, it is a good idea to install one, but make sure the tie wire is under the springs, and not on top of the springs.
What type of cam has the least chance of failing? 4speed57 Engine 24 01-29-2010 03:46 PM
new welding wire oldred Body - Exterior 93 05-07-2009 04:40 PM
3 wire alternator hookup GCD1962 Electrical 10 04-21-2008 08:29 PM
1986 Cutlass wiring Q's again :( ChrisMiddleron Electrical 12 07-16-2005 04:22 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
