s-w dimension or ppg shopline basecoat - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2010, 05:05 PM
would like opinions from people who have used them please. if you do not like one or other please give reason. just don't say JUNK because you heard someone else say it.
Old 12-06-2010, 10:42 PM
Rag top bird's Avatar
Hot rods are still the king
The most important thing is the color matchs they are not that good and the clears are not up to standard
Old 12-07-2010, 12:33 AM
if you want a good inexpensive paint with dreat color match look at gentec you can not go wrong with this paint
Old 12-07-2010, 10:25 AM
this is going to be a complete respray
Old 12-07-2010, 09:21 PM
If you are doing a all over then you would be ok with all of the cheaper lines other then the clear if I were to use say shop line base then I would use the PPG 2021 clear it has a better gloss and it will hold up better then the shopline clear in the long run
Old 12-07-2010, 10:09 PM
Last journal entry: Hood
Yeah I have seen the jc630 shopline clear breakdown after only a few years and its not very durable.
Old 12-08-2010, 05:50 AM
even the ppg,s-w jobbers said to upgrade clear. the truck will be a driver.
Old 12-08-2010, 05:57 AM
the truck is a 1993 with 36000 miles no rust except for frame. i will add new mirors,roll pan,paint front bumper and grill to match truck,billett grille insert. the truck has 3/4 drop
ID:	50679   Click image for larger version
Old 12-08-2010, 08:05 AM
deadbodyman's Avatar
Wiki Edits: 11
Check out pro spray base with SPI clear...It might be the best bang for the buck...
I didnt like the dimentions at all.I cant put my finger on why but I didnt like anything about it and never used it a second time
Old 12-08-2010, 08:25 AM
302 Z28's Avatar
Give the SPI clear a try, I think you will like it. If you choose to go with PPG clear the most durable and highest gloss is DCU2002.
Vince
Old 12-08-2010, 08:34 AM
shine's Avatar
Last journal entry: some progress
2nd line paint will cost the same as you will have to use more. dimension sucks period. omni is no better . prospray would be a better choice.
What do I do now..... Omni or PPG????? onebadmerc Body - Exterior 6 04-11-2009 04:42 PM
Suggestions on a paint system other than PPG camaro freak Body - Exterior 10 04-03-2007 05:32 PM
PPG basecoat over PPG NCP280 surfacer wickiewicked240z Body - Exterior 1 03-18-2007 09:11 PM
toughest paint acsteve Body - Exterior 29 12-25-2005 01:07 PM
PPG Base/Clear over new Acrylic Early B's Body - Exterior 9 02-04-2005 09:43 AM
