Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S10 2WD rearend mileage
Old 09-22-2012, 04:15 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
At 200,000 miles I would want to at least put in new bearings. The gears would probably be fine. I would check the axles to see if they were worn where the bearings run on them. This is a very comon wear area and requires replacement of the axles if they are worn. A 3.42 gear will help some with the gas mileage.
