Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S10 2WD rearend mileage
Old 09-23-2012, 08:10 AM
big gear head's Avatar
big gear head big gear head is online now
High Performance Rear Ends
The early S10 rear ends had a 3 bolt pattern on the brakes. One large bolt at the top and 2 small bolts at the bottom. Somewhere in the late '80s or early '90s they went back to the old 4 bolt pattern that was used on the old Chevy car rear ends in the '60s and '70s. The disc brakes use this 4 bolt pattern. If you have the older type rear end with the 3 bolt brakes then the disc brakes will not fit.
