S10 with a 350 and turbo 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2013, 08:38 AM
I am building a S10 dropped a 350 with a turbo 350 trans and do not have my motor mount kit yet but like to know if I have to build a mounting plate for the trans mount and what changes do I have to do with the drive shaft ? or can I use the stalk shaft till I get a good shaft
Old 04-21-2013, 08:58 PM
mickey1031's Avatar
i have a 88 s-10 ext. cab and it has the 2 pc shaft. however my room mate as a 87 and it is the single cab with the 350/350 and i believe they ended up finding a shaft for it.
you can use the mounts for the motor and i want to say we needed to find a cross member for his truck, but the body was off the frame so it was not as much of a pain to do his.
look at v-8 swap there is more info then you might think out there and on this site then you might want to know.
use the search button at the top and do a search for S-10 tons of links should pop up for you
Hooking up a 350 turbo speedometer cable to 96 s10 eric32 Transmission - Rearend 6 06-14-2009 06:58 PM
Installing turbo 350 into 96 s10 eric32 Transmission - Rearend 3 03-03-2009 07:26 PM
Newer 96 350 Block fitting to a old Turbo 350? Chevytruck Engine 5 10-07-2008 01:47 AM
v8 s10 converstion,700r4 or turbo 350? beach_boy327 Transmission - Rearend 2 03-06-2007 03:21 PM
I have a turbo 350 behind a 350 4bolt main in my 65 Imapala. It shifts into first an shepardb Transmission - Rearend 5 02-19-2004 03:41 AM
