s10 350cid what should i do - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2003, 02:02 PM
The Dead Man's Avatar
The_Hit_Man
Exclamation s10 350cid what should i do
was wondering how i should set up my suspension. i have an 88 chevy s10 pick up. how should i set up my suspension to hanbdle all the horse power i plan to put in it.
Old 09-21-2003, 02:53 PM
s15laynrubba's Avatar
www.s10v8.com
How much hp are you gonna be running? ...Jay
Old 09-22-2003, 05:42 PM
The_Hit_Man
around 350 to 410 horse with 377 to 477 ft lbs of torque
Old 09-24-2003, 12:05 PM
If you are wnating to put the power to the ground you need to look at four linking the truck
Old 09-24-2003, 12:42 PM
The_Hit_Man
what is four linking
Old 09-25-2003, 07:33 AM
i know a guy using cow tracks i think theyre called... kind of like traction bars but they bolt up on each end... pretty much adds a two link to the springs... he swears by them.. be a good bit cheaper than converting to a 4link coil over setup though that would be ideal... a 4 link is just 4 bars that pivot up and down that mount at the frame and the rear end... but youd need to change over to coilovers or airbags to use them.... the front suspention i cant really remember what brand of springs or the spring rate... i was to say comp engeneering... call them up though and theyll be able to help you out choosing.. youll want an easy up hard down spring... if you do switch to coils in the back figure out what size slick youre going with and talk to them about it too.... the stock suspension i think is enough to hold the truck up fine... and if youre using big enough slicks i wouldnt woprry about the front end much... the back at the least needs some traction bars though
Old 09-25-2003, 01:09 PM
V8 S-10's Avatar
v8s10.org
You mean CalTracs....not cow tracks.
Old 09-25-2003, 07:09 PM
yeah thats them
