Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S10 355 brakes don't work very well
Old 07-21-2012, 06:30 PM
s10quint's Avatar
s10quint s10quint is offline
Get yourself copies of the wiring diagrams for your truck & the donor vehicle. If you wire it inline with the ignition coil or another wire that only gets power when the switch is turned on, you should be fine. Should work on any type of vehicle. Foreign or domestic. Good luck!!!
