s10,46 dodge - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2008, 07:16 AM
s10,46 dodge
i am putting a 46 dodge pickup on a 84 s10 frame,I found out That I need that racheting/clutch cable pulley.I checked around and can't find info at the parts stores.Anybody had any luck finding one?
Old 02-20-2008, 07:42 AM
i'll be starting the same swap on a 48 plymouth. if you find anything let me know.
ill be starting the job in about 2 months, we should share info. i'll be making a project journal too, so look out for that.
Old 02-20-2008, 07:53 AM
stuff
i have the cab on mine,not finished bolted yet,but on there.Radiator shell is on and bolted,hood fitted.i am using the complete s10 frame and running gear.I,m trying to use the s10 firewall and acces.Cab is back a little further than I wanted it to be but had to to get the front tires to be systemectical.Having trouble with the clutch working and with the brake master cyl. hitting the hood,thinking of going to a manual brake setup without the booster.probably will run a Griffen radiator.Might have to put the project on the back burner as I was going to retire from oval track racing,got rid of my racetruck and such but couldn;t stand it so I just got another race truck to build
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 02:32 AM
Ford Econoline or Dodge A100 axle?? wheelsup64 Suspension - Brakes - Steering 4 02-13-2008 08:41 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 08:36 AM
Ford Econoline or Dodge A100 axle?? wheelsup64 Suspension - Brakes - Steering 2 01-26-2006 10:20 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
