Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S10 to '49 Olds?
  #92 (permalink)
Old 01-07-2009, 09:53 AM
oldguy829's Avatar
oldguy829 oldguy829 is offline
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
s10 to 49 Olds
One more thing ( It's a ***** when the old memory won't pull up the trivia like it used to). I can't remember if we confirmed the application for the 39 Olds.
If the info isn't in the WIKI, let me know. Size of the lower A frame, symetrical design, and mounting holes width on the cross member should be all you need to check.
